2004 evinrude 150hp direct injection
20 mako Kevin
I am having a problem sometimes getting up on plane. I changed plugs to champion copper but still had issue pull plug wires while at idle only firing on 4 cylinders. Is this a plug wire issue, power pack issue or bigger?
Chris1956
Honorary Supreme Mariner
Does that motor require you to index the spark plugs? I had thought the E-Tecs needed that.
