2004 Evinrude 115 etec lower unit (5004632) drive shaft question
Pete811
Hello, I recently bought the above lower unit to replace my damaged unit. After receiving the unit, I found that the drive shaft pulled out of the lower unit without any resistance. I looked in the drive shaft opening and I do not see a retainer clip. I don’t even see a hole for the retainer roll pin. The unit was described as a brand new, never in the water unit taken off so that a jet could be installed on the donor motor. Can I just put the drive shaft in, install the water pump and install it on the motor? Or do I have to take it all apart and install a retainer clip? You advice would be appreciated. Thanks
Pete811
[No message]
Pete811
So I don't need to lock it into the lower drive shaft? Since my post, I've found out its an S2 unit in which the upper drive shaft locks into the lower drive shaft with clips.
