2004 30 hp 2 stroke low volts HELP PLEASE!!!!!!!!!!!!!!!!
sbs1983
hi i purchase my boat a mounth ago it camwith fish finder lights etc but no battery i finally bought one and hooked it up and every thing works well EXCEPT my motor only puts out 5 volts at idle and 8 at cruiseing speed and this is no were near the correct volts to keep it charged why is this how can i fix it any help would be great thanx
ac0j
Re: 2004 30 hp 2 stroke low volts HELP PLEASE!!!!!!!!!!!!!!!!
Take the main battery cables off the motor, make sure they are OK, (no messed up ends and such) clean the attachment points well and see if that helps.
fucawi
Banned
if you have a 12v battery connected you cannot read 8v at the battery ..so where are you measuring this 8v.? you need to check the volts (AC ) comming from under the flywheel coils where it feeds to your regulator or rectifier.....2004 ..what is the make of your outboard ? You usually have about 16 v AC from under the flywheel ..if less than this measure with the wires disconnected ....if the voltage is then right your regulator or rectifier is caput .
sbs1983
thanks for your reply facawi it is a 30 hp yammaha there are 2 wires that come off the fly wheel and both measure about 2.5 volts they plug into a little black box and your battery termanials come out off there and thats were you get about 5 volts (at your battery terminals with no battery connected it is a pull start so no battery requied to start it ) at idle it does go up if you rev it flat out but i would have thought it would put out at least 12 volts on idle any help would be great than
Silvertip
Honorary Supreme Mariner
if you are reading ahead of the rectifier you need to have the voltmeter set to the AC (alternating current) scale. After the rectifier you need to set it to the DC (direct current) scale.
fucawi
Banned
Take the wires off that go to the recifier and measure the voltage at idle and gently throttle up ..you should go up into the 16 v range ...Set for AC as I said earlier ... If you get 16v and only 5 when you re connect your rectifier is bugggered ..cheap at Radio shack ..anything exceeding 10A and 50V will be fine ..Great motor the CV30
of course as we dont know what country you are in it could be Tandy or RS or **** Smith or J Car or Maplin
sbs1983
cheers thax mate will try that im in australia so parts will be easy to find thanx for your help will let you no how i go
