2003 Yamaha HPDI will not stay running, Stumped
dustin440
I just rigged my boat with a pair of 150s and they ran great on muffs but the first time I put it in the water the port motor ran fine and the starboard would start and die. It will restart every time but die immediately or within 10 seconds. I searched a lot and most things point to fuel but I have tried swapping almost everything from the good motor to the bad with no luck. Both motors share a fuel tank but have all new lines from the tank to the water separator on the engine.
So far this is what I have tried...
replaced both low pressure pumps with brand new because they leaked when i unbolted them and pumped the ball
tried running from a can directly to the motor
switched the water separator and filter, vst tank, medium to high pressure filter from good motor to bad
Took cables off and cleaned them and even switched them to the other engines battery
tried spare engine harness and key switch
looked for broken or corroded wires
Replaced mystery filters in in high pressure pump but not injectors yet
removed grounds, cleaned, reinstalled
The motor will run if unhook the throttle position sensor and I also tried switching that. I just got the YDS and hooked it up and everything looks good and when I unhook the TPS the high pressure pump fuel pressure is 690 at idle. I checked a volt meter and on the TPS I get 5v on the wire coming the computer.
I am really stumped and hope someone can help.
Thanks for any insight anyone has.
Dustin
Save dateJuly 11 2020 Save dateJuly 11 2021
ECM No.:68H8591A20 ECM No.:68H8591A21
Diagnosis Diagnosis
CodeItemResultCondition CodeItemResult
18Throttle position sensorIrregularOut of specification 18Throttle position sensorIrregular
13Pulser coilNormal 13Pulser coilNormal
14Crank position sensorNormal 14Crank position sensorNormal
15Water temp sensorNormal 15Water temp sensorNormal
19Battery voltageNormal 19Battery voltageNormal
22Atmospheric press sensorNormal 22Atmospheric press sensorNormal
23Intake temp sensorNormal 23Intake temp sensorNormal
25Fuel press sensorNormal 25Fuel press sensorNormal
26InjectorNormal 26InjectorNormal
27Water in fuelNo 27Water in fuelNo
28Shift position switchNormal 28Shift position switchNormal
44Engine stop lanyard switchOff 44Engine stop lanyard switchOff
Diagnosis Record Diagnosis Record
Total hours of operation1868 Total hours of operation1869
CodeItemOccurred CodeItemOccurred
18Throttle position sensor1868 19Throttle position sensor1869
Engine Monitor Engine Monitor
Monitor ItemResultUnit Monitor ItemResultUnit
Engine speed675r/min Engine speed675r/min
Fuel pressure (5.0±0.8)4.72MPa Fuel pressure (5.0±0.8)4.72MPa
Fuel pressure (725±116)690.52psi Fuel pressure (725±116)690.52psi
Atmospheric pressure997HPa Atmospheric pressure997HPa
Atmospheric pressure29.5inHg Atmospheric pressure29.5inHg
Ignition timingBTDC 7deg Ignition timingBTDC 8deg
Battery voltage (12-16)13.99V Battery voltage (12-16)13.99V
Oxygen sensor voltage (0-1.0)0.03V Oxygen sensor voltage (0-1.0)0.03V
TPS voltage (0.5-4.5)0V TPS voltage (0.5-4.5)0V
Throttle valve opening (0-90)-10.4deg Throttle valve opening (0-90)-10.4deg
Fuel injection duration1.47ms Fuel injection duration1.47ms
Water temperature (below 90)59°C Water temperature (below 90)59°C
Water temperature (below 194)138.2°F Water temperature (below 194)138.2°F
Intake temperature (below 70)26.3°C Intake temperature (below 70)26.3°C
Intake temperature (below 158)79.4°F Intake temperature (below 158)79.4°F
Electric oil pumpHigh Electric oil pumpHigh
Firing of cylinder #1Yes Firing of cylinder #1Yes
Firing of cylinder #2No Firing of cylinder #2No
Firing of cylinder #3No Firing of cylinder #3No
Firing of cylinder #4Yes Firing of cylinder #4Yes
Firing of cylinder #5Yes Firing of cylinder #5Yes
Firing of cylinder #6Yes Firing of cylinder #6Yes
Starter switchOFF Starter switchOFF
Engine stop lanyard switchOFF Engine stop lanyard switchOFF
Over-rev control release leadOFF Over-rev control release leadOFF
Main switchON Main switchON
Shift position switchON Shift position switchON
Water detection switchOFF Water detection switchOFF
Oil level switch (remote tank)ON Oil level switch (remote tank)ON
Oil level switch1(engine tank)ON Oil level switch1(engine tank)ON
Oil level switch2(engine tank)OFF Oil level switch2(engine tank)OFF
Oil level switch3(engine tank)OFF Oil level switch3(engine tank)OFF
Water temp switch (over heat)OFF Water temp switch (over heat)OFF
Dual engine system switchOFF Dual engine system switchOFF
Data Logger[Engine operating hours according to engine speed] Data Logger[Engine operating hours according to engine speed]
Engine speedTime[h] Engine speedTime[h]
- 1000 r/min1023.8 - 1000 r/min1023.8
1000 - 2000 r/min420.2 1001 - 2000 r/min420.2
2000 - 3000 r/min61.6 2001 - 3000 r/min61.6
3000 - 4000 r/min333.4 3001 - 4000 r/min333.4
4000 - 5000 r/min28.8 4001 - 5000 r/min28.8
5000 - 6000 r/min0.3 5001 - 6000 r/min0.3
6000 - 7000 r/min0 6001 - 7000 r/min0
Total hours of operation1868 Total hours of operation1868
Data Logger[Data comparison graph] Data Logger[Data comparison graph]
Engine speed[r/min]Fuel pressure (5.0±0.8)[MPa]Battery voltage (12-16)[V]Oxygen sensor voltage (0-1.0)[V] Engine speed[r/min]Fuel pressure (5.0±0.8)[MPa]Battery voltage (12-16)[V]
5004.6911.940.04 -243.99-393.253-542.516
5004.7212.160.04 -243.88-393.124-542.368
11504.8412.30.04 -568.81-913.052-1257.294
4004.6511.870.04 -194.025-313.291-432.557
5004.7212.010.04 -243.955-393.214-542.473
6004.7612.380.04 -293.77-472.996-652.222
4504.7212.160.04 -218.88-353.124-487.368
4504.7211.940.04 -218.99-353.256-487.522
5004.7211.940.04 -243.99-393.256-542.522
6004.7212.670.04 -293.625-472.818-652.011
5504.7212.740.03 -268.6-432.789-596.978
