2003 Volvo 5.0 GXi-B Changing impeller?
DrD
This Chaparral Signature 240 is new to me, and has about 250 hours on it. It seems like the raw water impeller can be changed fairly easily, but I have no experience with this engine. I have the Volvo impeller kit, and an expoded view diagram I found at www.dougrussell.com from their parts catalog.
I would appreciate any tips I can get before I begin this project. The engine is in factory new condition, with the impeller housing / bolts still bearing the original factory paint. For example, Do I need to remove the inlet and outlet hoses before removing the housing? Is there any gasket compound needed when reinstalling the housing? Are any special tools needed to remove / replace the impeller? What lube grease (if any) needs to be applied when reinstalling the hardware? And so forth.
Thank you in advance,
Dale
DrD
Re: 2003 Volvo 5.0 GXi-B Changing impeller?
That is just what I needed. Thank you!
Dale
