michaelnel
Thread starter- Joined
- Jul 7, 2016
- 16
Hi
I just bought a clean used Klamath 14 footer with a 2003 Suzuki DF15 4 stroke outboard. It is *very* hard to start when the engine is cold (cold around here being 90F air temp lately). The starting procedure I have used (I have no manual) for this pull-start engine is:
1) Pump bulb until firm
2) Full choke
3) Make sure dead man clip is in place
4) Closed throttle
5) Pull, pull, pull, pull, etc.
Sometimes it will start after 10 or more pulls, but this morning in 60F temps I pulled it about 30 times without so much as a cough. Tried full choke, 1/2 choke, no choke, no throttle, a little throttle... nothing.
The little red light does flash when pulling the cord, I assume that means ignition is working?
I tried replacing the two spark plugs, but the stock ones looked good, tan insulators and sharp electrode edges, slightly larger than spec gap. I pulled the cowl off and it does look like the manual choke valve is opening and closing properly. This 2003 has the Mikuni carb with manual choke, no enrichener that I can find.
When we succeed in getting the engine started cold, it idles smoothly, and runs great. Transition off idle is smooth, and it is smooth all the way up to cruise, and presents no more problems until the next cold start. Starts on first pull when it is warmed up.
I put some SeaFoam in the tank hoping for improvement, did not get any.
I will try some fresh gas. I don't know how long that gas has been in the tank, but I was under the impression from the owner less than a month.
Any other ideas?
2) Full choke
4) Closed throttle
Any other ideas?
