2003 Nissan NSD40B spark plug wire
Vwsandcar
I have a 2003 Nissan NSD40B TLDI that has a misfire under load. I checked resistance on all 3 spark plug wires. Cylinder 1 and 2 measure about 3k ohms. Cylinder 3 measures open. I would like to buy 3 new cables but I can only find them with the coils. Are the ignition cables available without the coils? Outboard also has a code stored for cylinder 3 ignition fault. New plugs had no effect.
Thanks.
Sea Rider
I'm not familiar with that motor model. If those spark plug cables are traditonally wired as found in old cars cables, check at a auto parts stores for those, need to be the same lenght and diam to be screwed to the ignition coils and spark plug's connectors...
Happy Boating
pvanv
You can make up your own; the Factory ones come on coils.
