Is it a big deal to change the prop shaft seal on the above engine? How do you get the old seal out?
F fishon71 Chief Petty Officer Thread starter Joined Jul 21, 2002 Messages 575 May 4, 2010 #1 Is it a big deal to change the prop shaft seal on the above engine? How do you get the old seal out?
O oldgradywhite Petty Officer 1st Class Joined Sep 7, 2007 Messages 232 May 4, 2010 #2 Re: 2003 Mercury 25 hp leaking prop shaft seal Its alot easier if you have a the right tools but if you are careful and take your time you can use a linse seal puller tool. I would have the dealer with the headache it is should run about $200
F fishon71 Chief Petty Officer Thread starter Joined Jul 21, 2002 Messages 575 May 5, 2010 #3 Re: 2003 Mercury 25 hp leaking prop shaft seal I have done other motors with dual seals just by digging them out but this single seal looks deep in there.
