2003 Mercury 115 two stroke misses when trimmed out.
finish line 88
Engine runs great without trimmed out. When I trim the motor while running I get a miss for a second or two. then it runs for 10 to 15 seconds and misses again, then again, then again etc.Trim it down all the way and runs great...
Checked compression 125 psi in each cylinder. replaced spark plugs,fuel filters,primer bulb, cleaned carbs. went over motor for possible loose wire.
Dont know what else to check.
Any help would be great
Honorary Supreme Mariner
Open low speed mixture screws on the top 2 carburetors.------Open them 1/8 turn at a time.------This motor only runs on the top 2 cylinders at idle I believe..
Faztbullet
Check connections at rectifier/regulator and cables at battery connection.
Sirrobin53
Mine were tight too
