2003 Mercruiser Engine Model Question 5.7L B3 and Mcgard stern drive lock problem...
homelite
Hello,
I bought a Vista 268 with locked up engine. Ingested water somehow. I need to replace the engine, which I am ready to do. Engine question is, on the side sticker of the air cleaner cover where it lists the Engine s/n, Transon s/n, and Drive s/n and the general specs my engine s/n is OM630863. Then I noticed on the rear of the same air cleaner cover is a black sticker that says the Engine s/n is OM636699. This sticker also references the engine family and says meet Calif emmissions standards.
Which is the correct engine s/n? Why 2 different s/n's on the same air cleaner cover?
Next problem is, when the original owner bought it new, he had a Mcgard stern drive lock installed on the middle stud. Before I get a cutoff wheel started spinning and cutting, any insight on a better way to remove the lock?
Thanks and I hope someone has the answers.
johnhenry3
Re: 2003 Mercruiser Engine Model Question 5.7L B3 and Mcgard stern drive lock proble
Hello,
I'm assuming the key is lost? Can you obtain the registration card? If so, you could obtain a replacement key from McGard.
The best way to cut it off, imo, would be a small hi speed cutoff wheel (only about 1/8" thick), slicing through the nut over the length...without ever touching the drive...obviously. You will not be able to cut the last 1/8" or so, but now you should be able to easily crack or split the nut (as 90-95% of the nut is cut). You will want to first secure the nut with a vise grip blocked against the drive to keep it from spinning when you are cutting. Wear eye and face protection as well.
Don S
I had one key that fit on every one that I ever ran into.
