2003 Mercruiser 8.1 HO No Crank No Start Fuel Pump Running
mckaras
Hello,
I'm having an issue trying to start my engine on a stand. There's enough juice in the batteries. Cranks and Starts when the starter is jumped. Fuel pump turns on when the key is turned. I changed out the starter relay with a new one and still the same issue. I've used this ignition switch set up on a dozen engines without any issues.
My question is what is the next thing to check on the engine? Could it be the 50 AMP breaker on the engine causing issues? I have another starter on the way just in case and will be picking up another ignition to change out with this one.
Ayuh,...... Instead of replacing stuff, Test the connections with a test light or multimeter,.....
alldodge
Agree
See if there is power on both sides of the breaker
Can also do it direct at the plug
If the fuel pump is running, then the ignition circuit is powered
Since it's not cranking:
Check the ignition switch
Check the neutral safety switch
Check the cannon plug terminal
Check the starter pilot relay
mckaras
Got it all sorted, I ran the wire back to the starter solenoid 8M0185149. No voltage at the wire connected to the solenoid when ignition was turned to start and no voltage at the solenoid where the starter solenoid wire connected. Thanks for all the help!
mckaras
Agree
mckaras
Well, I still the same issue. No voltage at the wire going to the solenoid. I checked voltage going to the ignition switch, cannon plug terminal, 50 amp breaker, and starter pilot relay and it has enough voltage.
The solenoid that the starter solenoid wire runs to has no voltage at the starter solenoid or the solenoid that the wire runs to.
The neutral safety switch I still need to check since it's still wrapped up.
mckaras
Agree
One place I haven't checked power at is the neutral safety switch. I'm just getting 0 voltage at the yellow/red wire going to the starter solenoid from the solenoid that's mounted under the ECU. Changed it out for a new one and I was still having the same issue with 0 voltage with key turned in the on position.
alldodge
With the motor on a stand there will be no neutral safety switch
Find the relays on the motor and find the one with a small and large Yel/Red wires.
When pin seven on the 10 pin plug has 12V applied to it it will go to the smaller of the 2 wires on the relay. The relay should energize sending power on the larger of the yel/red wires down to the starter.
The relay will have 2 yel/red, one black and one red/pur wires
The only change in this is if your motor is early enough to not use a square relay and in that case it would use the old slave relay
mckaras
It's a 2003 engine, it has the 3 square relays. There's no relay with a yellow/red wire going to it. I swapped over 3 relays from my other 8.1 with the 3 on this engine. Still the same issue, that engine starts.
I have the wiring diagram for this engine and there's a yellow/red going from the ignition switch/barrel connector to the slave relay (above) and one yellow red going from the slave relay (above) to the starter solenoid.
mckaras
The only spot that I did not have 12.4/.5 Volts going to was the red/yellow connection at the slave relay and where the red/yellow wire leads to on the starter solenoid. Every other connection with the yellow/red wire had 12V to it and I checked the positive connections at the starter, slave relay, and the 50 AMP breaker they all had 12V going to it. Key was in the off/on/start positions. No power at the slave relay and starter solenoid in start position.
alldodge
That's not right, Merc has uses standard colors and hasn't changed them since maybe the 70's
Some things are not clear for this old guy
I will assume you have the slave relay which I posted above
In that case all good
A Red/Yellow?
Post pic of this wire showing where it's coming from
496 wiring with slave relay
alldodge
I'll add a possible change, if this motor came out of a boat which has Vee or direct shaft drive, then the connections going to the transmission need to be jumped together
mckaras
It did have a ZF 63 transmission attached. I think that might be my issue then! I started the other engine when the transmission was attached still... I can't believe I missed it. Do I need to change anything electrical since I'm converting it for a sternboard? I have the other engine I will be taking out to swap over the old bellhousing, starter, etc.
alldodge
Only change need going from trans to I/O needed, connect trans wires together and make sure the neutral safety switch is connected to yel/red wire coming from ignition switch goes thru it on throttle handle
mckaras
If you can send me what connections need to be jumped since I detached the transmissions to list one of these 8.1s for sale and one for install that'd be great.
mckaras
Good to know. Thank you very much
alldodge
Wiring diagram in post 14 shows a Yel/Blk and Blk get jumped together
The wires should be at rear of motor
