2003 Johnson 90hp 2 stroke no spark j90glsta
Matthewarnett
ease Help. Have checked kill switch, replaced battery, ignition switch, optical ignition sensor, working with a known good power pack. Went through the CDI trouble shooting guide. When doing the ohms check on the stator orange to orange and black was 56 ohms. Although the brown to brown and white is supposed to be 450 to 600 but reads 1100. Could this be the problem. Pulled stator not any significant goo dripping but there where a few hardened droplets. Flywheel magnets looked good. I can't v remember where I found it now but there was ca voltage check from the stator that should have read 25 v I had 4v could this be due to the high resistance in the stator?
Edit Post???Reply???Reply With Quote???????
