I just picked this up. I assume it uses a mix of 50:1. Am I correct? Thanks in advance!
jopaped Cadet Thread starter Joined Mar 10, 2012 Messages 9 Jun 16, 2012 #1 I just picked this up. I assume it uses a mix of 50:1. Am I correct? Thanks in advance!
H hidef Lieutenant Joined Aug 22, 2009 Messages 1,465 Jun 16, 2012 #2 Re: 2003 johnson 25 hp 25TESTR fuel/oil mix You would be correct. Make sure you use TC-W3 rated two stroke oil.
