2003 Johnson 140 hp tilt/trim problem
big shark
When I lift the motor up, the fluid sounds like it is bypassing a relief valve. Can someone tell me what the "manual set valve" does? Thanks Bruce
big shark
Yes the tilt and trim work. I topped off the oil tank with motor up. Can you tell me what the "manual set valve " does? Is it for bleeding the system?
boobie
It's for raising and lowering the motor manually when you don't do it electricly.
boobie
After you top it off run it up and down about 10 times and recheck the oil level. The noise may go away.
big shark
Can you tell me how to bleed the air out of the system. I will try to do that first. Thanks Bruce
