2003 horizon 200= do you have to pull the engine to replace the steering cable?
pae0332
steering cable is very stiff and i do not think ill be able to get behind the engine to remove it from the transom. has anyone done this without removing or at least moving the engine? 4.3 V6
alldodge
I haven't done it but have disconnected cable for testing. It can be done but if you don't have the room to get to it the motor has to come out
Lou C
When I replaced my steering actuator, I had to remove the exhaust on both sides to get at the actuator & the cable...not an easy job but my older model has less fiberglass in the way than the later ones...
