2003 Glastron GX205 5.0 Volvo fuel issues
twillroth
I have an '03 Glastron GX205 with a Volvo 5.0. I was on the lake today and opened her up a little bit, and after about 5 minutes it started cutting out and losing power. It almost seemed like it was running out of gas, but, granted the gauge works, it had 1/2 tank. We got a tow to the marina and put 5 gallons of expensive damn gas in it, and nothing. When we got home we took the fuel line off the carb and cranked it and had nothing. I can't hear the pump running. Is it loud enough to be unmistakeable? We had voltage at the pump connector. Any info would be great. Thanks.
Don S
Re: 2003 Glastron GX205 5.0 Volvo fuel issues
It would help to have some more info on your engine, like carbed or EFI, Full model number, or even a SN for a few of us would help.
When was the last tuneup, fuel filter change, and other preventive maintenance done.
Any alarms, temp gauge look ok,?????
twillroth
it's the fuel pump. i pulled the relay and put a jumper wire across the terminals and checked voltage at the pump connector. i had voltage there so i plugged it back in and had nothing. the pump wasn't running. just to be sure i took the fuel line off the carb and attempted it again...nothing. now here it is, labor day, and nothing's open. but thanks for the reply. next time i have an issue i'll be sure to include more info on the boat/motor. once again, thanks.
Zach b
i was just wondering were is the sending unit on this boat i have a fuel gage problem and it says alwas full and i would like to know to fix. if u reply thank u so much
