2003 Constant Overheat Alarm
Copecetic
When my father passed away earlier this summer I took it upon myself to finish a boat restoration project he had started before he died. Being handy with a wrench I figured it would keep my time busy and maybe do something to remember him by.
I managed to get the 25hp johnson outboard running today with a smooth idle for about 20 minutes. I shut the motor off and restarted it a few more times until I started hearing a loud shrill alarm as soon as I turned the ignition on. I immediately shut the engine off and started googling what could be happening.
I quickly learned it's most likely the overheat alarm which confused me even more. When the engine is running there is a strong stream of water from the top of the shaft and from the bottom indicating water pump operation right? The alarm sounds as soon as you turn the key now even with the engine off and comes on even after waiting 30 mins.
What could be causing this? I'm assuming either the alarm is stuck or the overheat sensor has broken due to the alarm sounding whether running/off or hot/cold.
When I turned me key on the alarm used to always beep for 1-2 seconds before going silent. Now it never stops a constant scream.
Is it worth opening up the throttle box to see if a contact has corroded is it non serviceable? I'm attaching a picture of the control unit.
Thanks guys!
Link to pictures :
