lipscomb11
Thread starter- Joined
- Aug 23, 2022
- 2
I have Mercruiser 350. The problem I'm having is it doesn't start sometimes- when turning the key, I get no fuel pump prime or audible tone. Then it will randomly fire right up, when it does that I get the tone and fuel pump. It has new plugs, wires, distributor cap/ rotor, batteries, alternator, Ignition, and crankshaft sensor. I still has the same intermittent problems. I bought the cam shaft sensor that goes under the Distributor cap/ rotor, but when I went to replace, the sensor wasn't plugged in and I'm unable to find a harness back there for it to plug into, is that normal?
SN OM621398
SN OM621398
