2003 bravo 3 lower shift cable barrel
homelite
I have this apart and can't seem to turn the brass barrel. Sounds dumb but even when holding the cable with vise grips I still can't and don't want to damage anything. Am I missing something? It shouldn't be tight at all.
Thanks.
Don S
Re: 2003 bravo 3 lower shift cable barrel
It's called corrosion. Have you tried some penetrating oil and heat?
Bt Doctur
I`ve got some servicable spares,they should be the same as the Alpha item.
chrisvr6
Mine won't turn either. It turns with the whole threaded rod. Is that bad?
homelite
I romoved the threaded part from the boat with barrell of course. Put it in the vise and heated it with a torch. That got it to turn! It was easy.
chrisvr6
I just watched a YouTube vid on adjusting and the guy said some are not supposed to turn. They are one with the rod. My barrel has a hole and something pushed through the hole to keep it from turning?!
