2003 altima
Johnson110
Please help I cleaned the troddle body out on a 2.5 nissan enigine with 34k on the motor, the engine now will not idle good it surges up and down at idle, is ther a idle control valve on this motor, where and how much does itr cost? apppericate any help!
Gary H NC
Re: 2003 altima
There should be an idle speed sensor.Sometimes they don't like carb cleaners.
Call your local auto parts and see how much.
i386
Re: 2003 altima
At only 34K miles wouldn't it still be under warranty? You could spend a lot of time and money doing trial and error on this one.
Johnson110
Re: 2003 altima
The car is my girlfriend's she does have the "gold warrenty" I am going to bring it to Nissan, ( found out you cannot use cleaner in the throddle body) I am wandering if they "NISSAN" will fix the car, It has to have a new throddle body put in parts from NISSAN is about $180.00, yea I screwed up on this one! I am going to tell them that it started to surge up & down which is what it is doing, do you that they will fix it under her warranty? I have a 94 jeep grand cherokee 4.0 cleaned that TB no problem, Also have a 92 camry 4 banger cleaned that one too no problem! Guess it not like when cars in the 60"S & 70's could clean up carbs and adjust them!
Windykid
Re: 2003 altima
I wouldnt tell them anything except that it wont idle.
Re: 2003 altima
I sujest getting and reading the service manual for the car. Did you say why you needed to clean the air intake assembly?
Manipulator
Re: 2003 altima
I have an Altima, 2003 too. I cleaned out my air intake and the air cleaner with water to get all the bugs out. The air cleaner was saturated with water. I started the engine and figured a little water in there won't hurt, if anything it would clean out some of the carbon. After running the motor it ran like crap. Same symptoms you're having. I brought to the dealer and just told them my wife drove through a large puddle and the motor stalled. That's right, blame the wife hehe. They hooked it to their computer and found nothing. Said to drive it for awhile and if it keeps acting up to bring it back. I drove it for a few weeks and the problem resolved itself. Their has to be some type sensor in the throttle body that is very sensitive to moisture. I used compressed air to dry it out at first and it helped. This car is all computer fly by wire. No throttle cable either, all run by computer and sensors. Hard to play around with this setup.
If you go to the dealer play stupid. Like mentioned, just say it started to act like this all on its own, otherwise they will tell you that the warranty was voided by using carburator cleaner or whatever it was.
SpinnerBait_Nut
Re: 2003 altima
I wonder if the CEL came on. If so, they will see some kind of code for it.
Johnson110
Re: 2003 altima
yes the check engine light is on a staying on, off to the dealer tomorrow, I am going to tell them it just started to idle bad, started the car up yesterday and it has a high idle, and yes the CEL lite is still on!
SpinnerBait_Nut
Re: 2003 altima
Take it to a parts house, autozone, advance etc.
They can and will get the code for you and then you will know about what the dealer will know.
mrfixitman40
Re: 2003 altima
if she has gold warranty coverage take it in to them and let them fix it even if there is a deductable it will be cheaper
Johnson110
Re: 2003 altima
I know she has the gold warranty, I guessing that they cover it, how much would the deductable be? I never myself owned a brand new car, her father told her to go for the gold coverage!
mrfixitman40
Re: 2003 altima
not sure about nissans extended deducts, i know with ford you have an option of 0,50,100. each one changes the purchase price of course but not the coverage.good luck. let is know what the code is
Johnson110
Re: 2003 altima
Ok brought the the car to Nissan , changed the throttle body and it was covered under the warranty!
JCF350
Re: 2003 altima
Yep,doubt they have a way to tell if something was sprayed down the throttle body.
Some vehicles use a special coating that carb cleaner will damage.
There are intake cleaners out there that are detergent based that won't do this damage.
