2003 9.9 merc. 4 stroke sail power with electric start
stormmnv
engine will not engage starter when "start button" is pushed.. power to solenoid, safety switch is ok, starter button ok, fuse is good, other than bad solenoid what else is there?? any ideas would be appreciated..
Star
Do you hear the solenoid click when you press the start button. If not go buy a volt meter at Walmart and check for 12 volts DC. A bad ground or battery connection can kill your voltage when you pull current like a starter!!!
