Hello,
I have a Johnson 60 HP 4 stroke (J60pl4st), just recently it started to miss and stutter idling and when accelerating, full throttle it runs normal. The motor has a neutral rev limiter on it @ 2800 rpms, sometimes when in neutral it can be run up past the 2800 rpms. The problem doesn?t happen all the time.
I have changed out the water separator previously and most recent I changed out the fuel filter and checked the fuel lines for tightness, the fuel connector was a little loose, so I cut the line and reattached the connector. I have checked the plugs and they are spotless. I added more fuel in the tank with the omc fuel conditioner.
