2003 4.3gl PEFS overheating, please help
richardn
I replaced the impeller and pump. It was still was getting hot about 190 so I shut it off. I just replaced the thermostat and found some impeller pieces of an old impeller in the hose to the thermostat housing. After replacement of the thermostat it is still getting to hot. Is there a air bleed in the system? the housing had some corrosion so I tried to clean with a wire wheel. could I have plugged an air bleed???????
cptbill
You need to check all the little passage ways in the T stat housing and make sure all the impeller pieces are cleaned out of the system
Find all the old impeller bits. You may need to back-flush
ESGWheel
Ensign
There is no air bleed. Did your previous Raw Water Pump (RWP) impeller disintegrate due to the corrosion inside the housing? Was this the first start of the season? Also, you said “replaced the impeller and pump”. The rubber impeller is in the RWP on the crankshaft. Did you also replace the ‘circulation pump’ located on the block? Trying to figure out the history that led up to the overheating and make sure talking the same thing.
If you removed the RWP it’s easy to get the hoses backward, are you sure they installed correctly?
Also, if you wire brushed the RWP housing where the impeller goes it may not be sealing now or rapidly eroding the new impeller.
And was it running on a garden hose or in the water. If on a hose while on the trailer, did you get the expected water flow coming out of the exhaust, etc.?
Assuming no engine issues like an extreme lean condition, overheating is due to insufficient water flow due to not being pumped (like the busted impeller) or a blockage preventing the flow (like impeller debris in the system) or a broken connection and thus sucking air.
Please provide the history that led to the overheating as well as pictures of the old impeller core and the inside of the RWP housing and the good folks here will help you get to the solution. :)
