2003 250 saltwater series oil transfer pump
Crowiv
I posted a question about an oil alarm several weeks ago which was answered with advice on checking for clogging in the remote tank. Just got back to the boat today and think I have a more serious problem. After checking the engine oil tank it is low so there is no question I have a transfer problem as the remote tank is full. When I attempted to use the emergency switch to transfer oil it would not work. Port motor's switch works fine. Does this mean I have a bad pump on the starboard motor? If so, is this a repair u work recommend only be done by mechanic? If can be done by me, where is the pump located typically? Thanks
Re: 2003 250 saltwater series oil transfer pump
Put Direct Power To Pump On Remote Tank, See If It Runs, If It Does Then 90 Percent Chance Its The Harness , Check Coupling On The Harness At Motor, Check Contiuity On Wires From Tank To Coupling On Motor, Could Have Bad Ground, Especially Brown Wire, Have Ignition On When Checking, I Have The Same Problem Just Did Not Have Time To Get To The Boat
