2003 225 DI Running Rough at idle & low RPM's
jtecker
When I winterized the engine last fall it was running fine. The fuel was treated with Sta-Bil. When I commissioned her this spring I changed the spark plugs (properly indexed) and the fuel filter on the engine. When I started her up she ran rough from idle all the way through about 3500 RPM's but from there up to WOT she screams just fine. I thought it was possibly the fuel but I've now used up most of that left over fuel and have re-filled with fresh. I probably have another 5 hours on her with the new fuel but same problem. I'm not sure where to look. If I had carbs these symptoms would be exactly for clogged primary jets but I don't think this engine has primary and secondary injectors??? Any thoughts on what might be wrong? Maybe a Seafoam treatment is in order to unclog something?
boobie
Get a laptop put on it and see if you have any codes. As a guess , you could have some injector problems.
