I have a 2003 4 stroke F115 yamaha. Over the last couple of months if i run hard (over 4000 rpm) for 20 + minutes then shut down and try to re-start after about 10-15 minutes it will not start. (If i try after just a few minutes it will start). Turns over strong but will not fire. Tried pumping bulb, cycling key 3 or 4 times, advancing throttle but nothing has worked. Generally if it sits 30 minutes to an hour or so it will re-start and run perfectly again until shutting down again.
If anyone has had this problem and solved it i would appreciate you letting me know what you found.
Thanks,
Thanks,
