2002johnson175[wont idle in gear]
joe g
hi, motor has less than 60hrs. Starts okay, but put it in gear and it dies. It does this about 4 or 5 times. I am able to leave the dock with motor shaking & spiting. After 3to 4 minutes it runs good at cruising rpm. When I bring the throttle back to idle in gear the motor dies. It does this every time. Brought boat to a mechanic at Dixie Marine in South Florida. They charged me $400 and I believe my situation is worse. I could use any help anyone could give me. <br />Thanks a lot<br />Joe G.
Hooty
Re: 2002johnson175[wont idle in gear]
Welcome to Iboats Joe.<br />How many rpm is the engine turning when idling in gear? Should be about 650 rpm.<br /><br />c/6<br /><br />Hooty
joe g
Thanks Hooty for your reply. My friend told me to check the adjustments on the carbs. They were about 8 turns out. I seated them and turned them 4.5 out and it seems to be running much better. I will be putting it in the water tomorrow. I will let you know what happens.<br /><br />Thanks,<br />Joe G.
