2002 yamaha v150tlrz wont get above 5000 rpm and super slow out of the hole
Jcouvillon
Hopefully someone can steer me in the right direction. A couple days ago I was at the lake. Boat started out running like always(good). I fished around for a while and decided to move spots I wanted to air it out a little since it rarely goes above 4000 rpms and it ran fine for a minute then it backed itself down to 5000 rpm. I then came off pad and boat idled fine, tried to get it back up on plane and it took forever. It usually jumps out of the hole. I get home and immediately do a compression check it was exactly 100psi on all 6 cylinders. I changed the plugs, changed the primer bulb just because i thought maybe it wasn't getting any fuel. The new bulb will build pressure but it won't hold it for about 1 min. I took it back to the lake today and it still won't jump out of the hole or turn over 5000 rpm. Would fuel pumps on side of motor cause my issues? Thanks in advance
