2002 tracker pro deep v combo WT wiring for bilge lawrence fish finder volt meter
pacobirdup
First time out boat was great. this year had to charge both batteries. got out on lake no fish finder stereo volt meter bilge. Blown 3 amp fuse in box fuses good in battery compartment. anyone got wiring diagram or know if any wires are run under the floor near the walk through. Stereo would go off briefly when stepping on section of floor.
Silvertip
Honorary Supreme Mariner
Re: 2002 tracker pro deep v combo WT wiring for bilge lawrence fish finder volt meter
You apparently have two problems since the volt meter is on a totally different system than the bilge pump an fish finder. There are two electrical systems on your boat. One system consists of the large battery cables that run to the engine. An electrical harness runs from the engine to the helm and that sysatem is what powers the instruments including the voltmeter. If you check the battery area you should find red and black #8 or #10 wires that run up to the helm. This system powers all other accessories. It is this system that the locator and bilge pump would be powered from. Those two wires would likely pass under the floor. The engine harness goes up the side of the boat to the control box.
