2002 nissian
16ftsunbird
I have a 2002 nissian 15 HP nsf 15b how often does oil and filter need to b changed what kind of oil and weight also need oil filter num i drive tractor trl and need to pick this up at a auto zone or some where like that as the boat shop will b closed when I get in today
pvanv
That info is in your owners manual, which you can DL from http://tohatsu.com/tech_info/manuals.html
Oil changes should be every 50 hours or annually, whichever comes first.
You need NMMA type FC-W, SAE 10w-30. It holds about 1L. DO NOT overfill. The oil level on the dipstick should be at or a little below the full mark; not even a drop above. When refilling, it will take significant time for the oil to read on the stick, so again, don't overfill.
[FONT=&quot]Tohatsu-Nissan 4-stroke models 9.9hp thru 30hp use OEM oil filter part # 3R0-07615-0.[/FONT]
[FONT=&quot]You may also use any filter listed in the cross reference chart below:[/FONT]
ManufacturerPart Number
ACPF1237
FRAMPH6607
LEELF2876HP
MAZDAB6Y1-14-302
MOTORCRAFTFL816
PUROLATORL14622
SUBARU15208-KA-010
WIX51365
You will also need an oil filter wrench. Your local auto parts store may or may not carry one that fits.
Sea Rider
Paul,
It it's a 4 stroke engine, like a motorcycle engine placed vertically with a prop, does oil gets very dirty as to change it at just 50 worked hours or it's a making oil issue just in case ?
Happy Boating
pvanv
Actually, the owners manual says every 100 hours or 6 months for that model, but most of these motors don't get more than 50 hours use per season.
