2002 Montauk, 90hp Merc, need Prop Suggestions
Ojaba125
Just picked up a 2002 17' Montauk with a merc 90 2 stroke same year. I am looking to get the most out of this engine, but def could use a little more on the top end. Mostly fishing, however, instead of the standard 12 gal tank I have a built in 28 gal which obviously adds a bit more weight. Looking for Prop suggestions, Thanks
steelespike
Re: 2002 Montauk, 90hp Merc, need Prop Suggestions
If you answer the questions in the stickys at the top of the prop forum it will help us select a prop for your particular application.
