2002 mercury 40 hp 2 stroke problems
justin67
hey guys i could really use some help before i start replacing the wrong parts. I was out on the lake the other day and when i started my boat the starter kept wanting to be engaged. the kill switch would not shut it off and i had to pull the terminals off the battery. everytime i try to reconnect the battery it instantly tries to start. now would this be my starting solenoid thats bad or what else could it be thanks for any help.!
Barnacle_Bill
The kill switch has nothing to do with the starter. Either your starter solenoid is stuck closed or ignition switch is bad. Take the yellow/red (I think) wire off the solenoid and try again. If it still does it its the solenoid. If not its the switch.
