2002 Merc 5.0
Machasin
Hello,
First post here because everything has been flawless until now.
189 hrs only. Bellows changed two years ago.
Trim will go down but will not come up. Will only rise if using trailer mode. Trim gauge and speedo not working also. Are these three items all related to one another?
What steps can be made to troubleshoot?
Any suggestions would be very helpful.
Not sure what else I can tell you. The boat is now in the water and not easy to bring in for service.
2002 Crownline LPX BR
Thanks
Re: 2002 Merc 5.0
Ayuh,... Sounds like the wires broke off the trim sender, 'n switch...
The speedo tube is also probably disconnected...
The Drive, 'n gimbel housing need to be pulled to fix 'em...
