2002 Johnson 60hp four stroke won't start,
flkeysdan
I have a 2002 johnson 60hp four stroke that won't start. I was getting ready to take it out on Sunday and when we put it in the water, it wouldn't start. The trim and tilt didn't even work. Before putting it in the water, I started the engine, checked trim and tilt and did my inspection before leaving for the ramp. Everything worked fine. Once I got to the ramp, nothing would work. At times ,I did hear the clicking noise. Took the boat home and tried to figure out what was wrong. Prior to this, my mechanic had noticed that the safety wire had been cut by someone previously. He should me how to wire it and I did and no issues. I had the boat on the water and everything worked before this time. I am thinking that some how a wire is loose somewhere since my friend pulling the trailer went over a bumped that jarred the boat a bit. I have checked the batter connections and they are good. I checked the neutral position on the motor and that is fine. I just cant get any power. Trim and tilt won't go up. I just had trim and tilt motor replaced and starter solenoid as well. I had to reconnect the two yellow and orange wires that had been cut. Any suggestions and diagrams of the safety switch or starter in neural switch will be greatly appreciated.
flkeysdan
I read about the fuse earlier but I dont know where it is located. Is there somewhere I can find a diagram that will show it. I do have the repair manual. Thanks for the respond.
flkeysdan
I went out and checked some wires, and it started to turn over than stopped. All I got was clicking. Tried to find the fuse without luck.
Silvertip
Honorary Supreme Mariner
Weak battery or bad (corroded) battery cable terminals.
