2002 Johnson 50 'chugs' at 3000 rpm
GrahamR
I have a 2002 Johnson J50PL4ST fuel injected 4 stroke. It runs great, EXCEPT for the first 5-7 minutes. When I first take it, out when it's cold, it will not go past 3000 rpm. When I try, it 'chugs' and I have to back off the throttle. After about 5-7 minutes of driving at 3000 rpm, I can move past 3000, to normal operating speeds. And after it has warmed up it doesn't seem to have this problem.
Does anyone have any suggestions?
Honorary Supreme Mariner
Check for a sticky neutral switch.------A part found on the MOTOR shift linkages.-----Not the neutral start switch found in the control box.
oldboat1
I would think in terms of filter cleaning or replacement, and injector cleaning. Should be a procedure in the service manual (might try Ebay for a manual).
