I need some help before I take a match to the boat. I have a 2002 Johnson 175 that will idle great on the hose, but won't idle when launched. Things that I have done so far in an attempt to get this motor running reliably.
New fuel line from tank to motor
New fuel filter
New fuel hand bulb
Rebuilt carbs with all new gaskets, needle valves and seats
New shift and throttle cables
rebuilt shifter
port side temp sensor
new water pump
Gas is good and when I changed the fuel separator and poured it into a glass, there was barely a drop of water in it.
The power pack was replaced by the previous owner just before buying it last summer.
Please guide me in where to look next. I'm going to try and check the timing next.
New fuel filter
New fuel hand bulb
rebuilt shifter
new water pump
