2002 Johnson 115 starting issues
thecheapergeek
Hello, i am new to this forum and completely at a loss. I have an 02 Johnson 115 and am getting nothing when trying to start, no click or anything. I had several problems last year and changed the solenoid and starter when i had this issue. I actually went through 3 solenoids. Changed 1 and it worked then suddenly stopped. Changed again and worked for one start then i changed starter and everything was good for remainder of season. Now i tried starting in the driveway for new season and nothing again. I changed the solenoid for the third time and nothing. (Each solenoid removed felt like spring inside was shot, you could hear magnet loose inside)
So far this year i tested neutral safety switch via ohm meter and it is good. Key switch @ b has 12v and upon cranking starter lead sends 4v. Small terminal@ solenoid also reads 4v. Battery is new and reads 12.6v. Jumped 2 big terminal and starter will spin but needs solenoid to activate bendix i understand. Any ideas? Anyone know what small terminal should be reading? Any one hear of this solenoid problem, my guess is something is causing solenoid to blow. Help p is greatly appreciated.
SparkieBoat
it sounds like you either have undersized wire going to the solenoid or a bad connection causing the overheating problem.
thecheapergeek
All conections were cleaned with electronic cleaner and matal surfaces sanded when replaced. I will check actual conections for corrosion but wires all original oem so unlikely undersized. Friend said possible voltage leak from yellow red stripped wire. I just don't get where leak could be. Think bad key switch?
thecheapergeek
So i went through all connections from harness plug to motor and found the connector plugs were corroded and cleaned them thoroughly. I also discovered that the red/purple wire has a splice between the two plugs and was broken; repaired now. Now i get the motor to turn over intermittently. Anyone hear of an intermittent ignition switch?
SparkieBoat
possible, but I think that you need to do some more wire checking, try OHM testing some wires including the ground wire. for you to burn up 3 solenoids tells me you got an issue. I have seen that before with undersized wiring, but i suppose a bad connection could do it as well. or your starter may be shorting out.
