2002 four Winn sundowner dash removal
Ryan22
How do I remove the gauges , I have two that do not work, does the dash need removed? If so how, I got two loose but the wiring is to short to pull through? Help me!!
there is either a complete panel that gets removed, often requiring the helm to be removed, or there is an access panel
mr 88
Not sure if you mean you cannot access the back of the panel ,which Scott replied to or you can't get the gauges out of the panel. If that is the case most gauges have a bracket on the back which pushes against the panel and must be removed before it will pop out of the panel. Are you sure it is the gauges and not a bad wire where it connects to whatever sending unit they are attached to ?
