2002 Ficht 225 block splitting
jedimaster
Trying the split the block from the crank case and it looks like it's coming if I apply a bit of presume to the pry points looks like the metal dowels are frozen. In place. Any tips on getting this to pop out?
jedimaster
Def the dowels holding. Top one I got loose bottom is really froze on there. Is it safe to hit the block with some heat?
Is the block off the exhaust housing ?---------Those dowels are tapered and they are easily removed .-------You are sure all the bolts are out ?
jedimaster
All good. I 3nded up drilling a hole through the lower dowel and punched it out.
