Just purchased this boat - everything seems to be in good fairly good shape except the previous owner made some modifications/additions to the electrical system:
The radio is not the original, and when he replaced it - the new radio had 2 additional speakers that he added in randomly below the dash (in non marine grade wood by the way...) and a 12v plug has been added on the passenger side - which appears to be potentially tied to the accessory switch, but I'm not 100% sure yet. :facepalm: The radio doesn't work well - when you crank it up it shuts off, like pushing too many watts causes it to reset - and sometimes when it 'resets' it takes several minutes to even show that it has power going to it again.
Additionally, when I switch on the Nav lights - it took it a few seconds to come on, but the anchor light comes on immediately on the same switch...and there is a separate anchor light switch that works also.
So I went under the dash and (not being an elec expert by any means) I just wanted to see if I could see anything loose, etc. After looking, most of his mods were wired terribly, without connections and just using elec tape. Before I got to far into the spaghetti mess, just finger poking around caused the whole elec system to shut off. I hadn't unplugged anything so I got a little worried and just tried to see if I could follow the wires back to the battery to see where the fuse panel was getting its inital power from. I saw where the main positive lead connected to the motor from the battery, but not where the smaller wires tied into that to feed the fuse panel.....
Then, without doing anything, the power came back on.
So here are my questions. 1 - does that sound like something that jumps out at you? 2 - does it make sense to try and redo that fuse panel under the steering column with new/good wiring? 3 - is it common to not try and tie the radio into the main fuse panel on the drivers side and just add a new one on the pass side for the radio and 12v plug?
