2002 Basstracker 165
tiger6
Looking to install a seat pedestal in the floor between the front and back deck. Is there enough clearance between the floor and the bottom of the boat to install the plate for the pedestal? Any advice?
jigngrub
Re: 2002 Basstracker 165
My advice is to install your base OEM with 1/4-20 stainless steel "T" nuts on the bottom of your decking, this will require removing the decking from the boat... but you won't have to worry about clearance between the bottom of the deck and the hull because you can cut the 1/4-20 bolts off flush with the bottom of the decking.
