2002 Alumaweld Super Vee wiring schematic
Bob Schulz
I was having trouble trying to get my fuel gauge working, so I took my breaker panel out to look at it and it is pretty well toast as far as corrosion on the terminals and fuse containers not latching properly any more. I would like to replace the whole thing but it would be very helpful to have a wiring diagram- only one problem- there seems to be a conspiracy between Alumaweld and the rest of the world about sharing their wiring diagrams or publishing them anywhere... Anyone know where I could find an Alumaweld wiring schematic so I can get this taken care of? Any other ideas?
TIA,
Bob
alldodge
Boat wiring is based on the motor installed and not so much on the manufacture of the boat. Once your past the motor then it just uses basics. A fuel gauge would not have a fuse in line with it, this gauge and rest will feed off the ignition fuse/breaker which would normally be 20 amps.
