2002 50hp 4 stroke eng. oil in raw water
Anchor Management 1
There is engine oil coming out of the exhaust,large amount till it empties the crankcase of oil.I can fill the crankcase with oil and in about 15 min.there is none left everybit of if is on the ground,but the engine runs perfect.And there is NO water in the oil or crankcase.
I have removedthe powerhead and rebuilt the oil pump(was told to much pressure) but it did not fix it.Now the powerhead is back off again and thinking about pulling the head off to check the gasket?
