Re: 2002 40hp Mercury 2 stroke knocking noise
Thanks a lot for that.
I've recently been contacted by someone who has owned an identical motor to mine since new. He says that his has always made that noise and when he had it checked out at the 20hour mark there was nothing alarming found to be wrong. He's put a lot of hours on it over the last 10 years and apparently it hasn't become any worse.
I also spoke to my local mercury dealer and he was quite adamant that he had heard the same noise and known of the same exact symptoms many times in the past... I would love to put into words how he explained it to me, but I'd probably relay it incorrectly and just cause more confusion.. However, I will say a few key words - Something to do with how the engine cuts spark to avoid over revving and it's related to something at the top of the powerhead. He also explained it as a type of harmonic 'resonance' (sorry, I can't recall the actual word he used).
Having ruled out rod bearings, top cam shaft bearing, timing and a host of other possibilities my options have boiled down to a) Having the powerhead stripped down for diagnosis, which could be an expensive waste of time if what I've discovered leads to be correct or b) running it as-is for the time being and keeping a very close ear out for change in the noise. If it worsens I'll get onto it promptly - Though I know by that point it's possible it'll be already too late. A calculated risk.
I'm off for a fishing comp over the next few days. I'll see how it goes and when I get back I might look at contacting some more marine mechanics for their input on the matter, especially those who regularly deal with/in Mercury outboards.
What I am absolutely certain of is that in the literally DOZENS of hours I've put into researching this problem I've only found two video clips with the same sound, which both turned out to be a problem between the flo torq 2 hub and the particular prop they were using and I've found only ONE person with the same motor who has the exact same symptoms and his has run fine for a decade.
If I had the money to spare I'd just get it torn down to be sure, but I don't. So I'll investigate some more, keep a close ear out and MAYBE I'll consider tearing it down myself and doing whatever work is required as I find it. I feel confident enough to get it right providing I take my time.. A hard ask over summer!
Thanks again
Matt.
