Is it normal for gas to spit out of the tiny hole in the diaphragm? In the image below you can see the small hole under the top left bolt. It only spit out little at idle but when i give it throttle a lot of gas spit out. It is only happening to the top one. The boat is idling very rough as well. I have left the motor untouched for about 6 months. Then when i took it out the motor was stalling out on me, i figured it had to deal with the bad fuel. So i flushed the gas, put in new spark plugs, changed the water/fuel separater, and outside fuel filter and the boat ran fine for awhile and i thought everything was fixed so i decided to go fishing. When i started the boat up back up after fishing, i see that my engine started idling rough again and the throttle wasnt responsive anymore at low throttle like the gas is clogging somewhere but when i put it at WOT it kicks in and goes fine. Please help thankss
