I have a hard to start problem with this motor. I try to start it with the red choke lever in "Normal" position and it starts for 10 seconds, sputters and dies. If I start it with the choke in the "Open" position it starts runs and idles perfectly. I have rebuilt the carbs, set the screws on the carbs out 1.5 turns open, checked timing marks, verified the prime start system is working properly. I put in new plugs, verified they are firing, new fuel filter etc. I do not know what else to check. I unplugged the blue wire from the prime start verified 12v with engine turning over and verified the that the thermo heater plunger expands and contracts as it should. Compression in all cylinders is 125. What else should I check and what harm is there if I run it in the choke open position? Thanks, Tom.
