2001 Yamaha 150TXRZ Alarm
Bay stealth20
***HELP***I recently changed my Impeller & Thermostat?s. I can run engine in a barrel and it does fine, as soon as I put the boat in the water, the alarm goes off! Thinking it may be oil issues? How can I diagnose engine to determine if it's water, cooling or oil pump issues? The oil reservoir on the power head has two lines, and the oil level is at the very bottom line of the tank. I don't think it's overheating because I ran the motor without the thermostat covers while in the barrel and the water pressure was good. How can I diagnose oil pump/float/sensor????????
Capt Ken
Re: 2001 Yamaha 150TXRZ Alarm
If the oil is at the bottom line, then you are getting a low oil alarm. How much oil is in your boat tank?
Bay stealth20
The tank in the boat is full,what would make the oil level in the resivoir drop?it used to stay about half full..
99yam40
The motor uses the oil in the tank, that is what causes it to drop:lol:
Apparently your transfer pump is not pumping oil from remote tank.
There are lots of threads dealing with troubleshooting this.
do a search and Read some that Rodbolt posted and others
