2001 Vip Bay Stealth 2180 with 150 Johnson
khorton2911
I was going to install a 3 bank on board charging system. However, after purchasing and beginning the install I was not able to locate a channel to get the wires from the front trolling motor area to the back starting battery area. Anyone know how I can fish them through from front to back?
khorton2911
As an update. I did find the drain channel that goes from the front of the boat to the back. However, I am not sure if this a good place to put a power cable. Any suggestions if this is a good idea or how you would suggest doing it safely? My first thought was to use some 14/2 direct burial wire Since this can obviously handle keeping moisture out.
Any thoughts?
