2001 V6 2.5L 140HP Mercury running hot
Status
Not open for further replies.
McHaggis
Re: 2001 V6 2.5L 140HP Mercury running hot
Removing the LU to back-flush thru the stat openings will allow a much greater flow volume than with the LU in place.
Next time you have the LU down give it a try just to be sure.
Also, when the lower is down rig a garden hose directly to the water transfer pipe, if it fits well you may be able to look up to the upper end of the pipe's fit in the grommet in the adaptor plate to see if it is leaking or well sealed as it should be.
Great idea. I'll give it a go. Thanks
I know this is an old thread, but there is a lot of great info here. I wonder if the OP fixed his issue. It really sucks when people don't report back.
jbcurt00
Complaining about members that never report back, in an old topic that also never had any follow up, doesnt really do much either except generate a Mod's
response.
mission accomplished
Closed
Status
