2001 Suzuki 225 2 stroke running on 3 cylinders
hangten
2001 Suzuki 2 stroke firing on 3 cylinders. The engine will idle then die and does not have power to move boat. The engine will still rev above 3000 rpm in nuetral. The suzuki engine monitoring system shows no problems (overheating, low/no oil, high rev) to put the engine into a fail safe mode. I have been in a fail safe mode before and have been able to operate the boat to the max rpm allowed in fail safe mode and will idle just fine. This problem is not similar to a fail safe condition. All three cylinders on the right side of engine have no spark. Any help is appreciated.
suzuki321
Re: 2001 Suzuki 225 2 stroke running on 3 cylinders
hey i have a 1998 Suzuki DT 225 also with the same problem theres a guy i no that is a suzuki mechanic and we did sum testing and he told me its the CDI box(power pack) i dont no if urs does the same thing mine runs fine for about 3 to 5 mins on a plain then loses power doesnt run over 1500 rpms and only runs on cylinders 1,3,5 when the box gets hot i have been looking for a cdi box or about getting mine refurbished im hoping to get it done soon and i will let u no if it worked. i hope this has helped you kinda get a start
99yam40
You need to test the inputs and out puts of the CDI and ECU to see where your problem is
suzuki321
i get good power into the CDI box but not out my the guy i no works at a marine shop as a machinec and he helped test a bunch of stuff and thats where it all led to
hangten
Thanks, it's starting to narrow down to the CDI. I'll be picking up a meter to test it this week.
mth00005
It could also be the stator.(under the flywheel) I had one do that once.Lost power on one side.
hangten
mth00005, did yours loose power on one side and never came back or is it like suzuki321's problem. Mine is dead on starboard side from the get go. I ordered a meter should be here in a few days. I'll post my results.
hangten
After testing, the CDI was bad. Installed today and is running fine. Thanks for all replies.
